Wellpoint Water Pump Starts and stops
Hi All,
I have a well point water pump that has recently started to behave erratically. It used to run perfectly, but now it runs for about 30 minutes initially, then stops. After that, it starts and runs for approximately 5 minutes before stopping again.
Does anyone have any ideas on how to troubleshoot this issue? The pump is used for watering the garden. The graph below shows the pump's activity today. It was switched on at 13:30 and off at 16:30. During this time, the power draw indicates when the pump was starting and stopping on its own.
Thanks Marius. How does one tell that water level is dropping while pumping. The flow appears steady the whole time.  im thinking of filling up my  tank then do test run that way.
