solar expand advice
Hi All ,
I need some advice .
I Have
--2 luxpower 5KW inverters
--2 dyness 48100 battery's
--10 460 panels
i am looking to upgrade my battery's by 2 and panels by 10
i am struggling to find 48100 battery's .
can i connect 2 battery's on one inverter and 2 other like the dyness 51100 to the other inverter .
will that work ?
6 hours ago, Hein.hein said:
Hi All ,
I Have
--10 460 panels
will that work ?
If the inverters use parallel communication cabling, they must typically be connected to the same battery bank(Dc bus). Otherwise, the system will produce an error. The only way it could work if you split the loads between the 2 inverters so they function independently.
Edited by TaliaB
Spelling
