Communication between Pylontech US3000C and Voltronic VMIII
Hi, I have two Pylontech US2000B and a Voltronic VMIII 5k for about 6 years. Voltronic is on mode PYL and communicates perfectly with the master Pylon via RS485, with a home made cable, this one:
Now I have a new Pylontech US3000C battery module, whichi I must use as master, so connect Voltronic with it. I have read that I need a new cable for this battery, one like this:
So I have made one.
The results are:
  • US3000C does not communicate with voltronic with any cable, neither old or new. I have tried with only US3000C module, without US2000 modules connected. I have tried changing cable ends, one end in Pylon and the other end in Voltronic, and upside down.
  • US2000C communicates perfectly with old cable and with the new one! How is possible!?
So...  the only think I could do is... update the Voltronic firmware. Do you think this could be the problem??? or it has nothing to do?
My actual firmware is:
U1: 20.65
U2: 02.21
U3: 00.21
Do you think updating the Voltronic U2 firmware will allow communication?
Is there any posibility of connecting a US2000B and a US3000C using the US2000B (I updated its firmware recently to v3.4) as master ?
Thank you very much
Edited by TomasCrespo
Yes, I seem to recall that being necessary. I'm not at my computer; from memory 02.87 or 02.90 is the latest.
@Coulomb
I have just upgraded remote panel to version 102.73 and now US3000C communicates perfectly with Voltronic VMIII in PLY mode, only with the second cable.
I haven't updated main firmware (it keeps 20.65). Should I do it?
I have always thought firmware update is a dangerous operation
Good to hear that. Although x02.73 is over 2.5 years old  at this point. The latest I know of is 02.89. But no need to update if this works for you.
No, for the simple reason that there are no newer firmwares available. The latest I have is 20.59 from 2018.
Danger is a relative thing. Voltronic keep using very inexpensive opto couplers; they are so bad that they normally run them at only 2400 bps! For firmware updating, they are run at 4x that speed, which sometimes reveals a slow one, and it can get hairy restoring operation after a failed reflash.
