March 26, 20197 yr 57 minutes ago, Dan said: What setup do you have running that? Three Multiplus 5KVA as three phase system, 2 x MPPT chargers on 6KWp PV array, 43KWh of flooded lead acid. All backed by a 55KW three phase diesel generator to give it a boost when needed. Will be upgrading to 10KWp soon and going on feed-in tariff. Lots of spare power available...
March 26, 20197 yr Author 8 minutes ago, The Bulldog said: Three Multiplus 5KVA as three phase system, 2 x MPPT chargers on 6KWp PV array, 43KWh of flooded lead acid. All backed by a 55KW three phase diesel generator to give it a boost when needed. Will be upgrading to 10KWp soon and going on feed-in tariff. Lots of spare power available... So all I need is a mini power station 😉 Thanks for the info
March 26, 20197 yr 8 minutes ago, Dan said: So all I need is a mini power station 😉 Thanks for the info Bulldog is next level, the rest of us are not. 🙂 If ever you want to find where to shop, once you have decided, drop me a PM.
March 26, 20197 yr 1 hour ago, Dan said: So all I need is a mini power station 😉 Thanks for the info Well, it has to serve a big house. You see when you go house shopping the wife looks at the kitchen. All I saw was a beautiful large north facing roof at just the right angle.😍 The diesel generator was already there (the house is kind of built around it - it has its own sound proof room, you cannot hear it when it is running). But I always wanted a nice clean solar power system. To be sure - it's not perfect - I would not mind bigger inverters, MUCH more battery capacity and more PV. I am adding more panels soon to make the feed-in tariff work but I can't go more than 10KWp - that's all the space I have left on that roof gone and other roofs are not that great due to position and shadows.
March 30, 20197 yr I have a 4kw infinisolar plus hybrid that is connected to the municipal power. It kan supply additional power as it is a hybrid. It has run at 120% load happily driving th pumps from the municipal side. I also have a 2.2kw borehole pump that I can run via the inverter. The starting amps for the Franklin borehole pump is 35 amps which settles to running 14 amps. I normally take the inverter out when I fill up my 2x5kl tanks. I prefer the bypass mode as it shows a load of 98% with the Franklin running. If there is load shedding I’ll start the generator to drive the borehole pump to fill the empty tanks. I have never started the borehole pump from the batteries alone. I use a seperate pump (from the tanks) for my garden irrigation. I don’t want to subject my inverter and batteries to unnessary high loads unless there is no other way out. Edited March 30, 20197 yr by Johandup
April 1, 20197 yr Author On 2019/03/31 at 12:23 AM, Johandup said: I have a 4kw infinisolar plus hybrid that is connected to the municipal power. It kan supply additional power as it is a hybrid. It has run at 120% load happily driving th pumps from the municipal side. I also have a 2.2kw borehole pump that I can run via the inverter. The starting amps for the Franklin borehole pump is 35 amps which settles to running 14 amps. I normally take the inverter out when I fill up my 2x5kl tanks. I prefer the bypass mode as it shows a load of 98% with the Franklin running. If there is load shedding I’ll start the generator to drive the borehole pump to fill the empty tanks. I have never started the borehole pump from the batteries alone. I use a seperate pump (from the tanks) for my garden irrigation. I don’t want to subject my inverter and batteries to unnessary high loads unless there is no other way out. Thanks - that's helpful information. I pulled our borehole pump over the weekend (installed by the previous owner) and found we're using a 1.1kw Franklin. Its running at about 8 amps once it gets going. Based on your experience it sounds like the 3KVA Victron may be able to the handle it.
July 23, 20223 yr Question regards a borehole and solar system. Have a 120m deep well with a 3 phase pump. Wanting to go off grid. Have a thought of using a solar pump 12 x 335 watt panels to lift min 2500 l per hour into my tanks. Will only really need 2 hrs a day. So for the remainder of the 4 or 6 hours, use the panels through a DC contactor to feed into my solar controller and 10kw lithium and 5kva victron for the house. Is this viable? Or should I rather find a pump that would do the job at 220volt from my inverter and be done with it? Thanks in advance Greg
