March 30, 20197 yr Have just been going through the video on Victron's Ess and for a newbie the controls/set-up look impressive. What advantages does Ess offer compared to other brands - why should I buy ESS? https://www.youtube.com/watch?v=tbpQzEZTElI Edited March 30, 20197 yr by Mistral Edit
March 31, 20197 yr @plonkster the best person to answer. Me, it works Plug and Forget and IF I want to change a setting, open a browsers from anywhere, login, and change the setting. 🙂
March 31, 20197 yr Well, it probably makes sense to first list the inverters that can actually operate in the same way, which I think is pretty much the Victron units, the Goodwe, and the Infinisolar. Price: Victron is the most expensive of the three. Let me be upfront about that. Expanding capacity by adding units in parallel: Only provided by Victron and Infinisolar. Remote monitoring and logging: VRM is possibly the best solution on the market for remote monitoring and even for diagnosis and support. And it is free. Interoperating with other systems: Only Victron has extensive modbus-TCP and MQTT capabilities for those who want to integrate their renewable energy setups with other systems (eg home automation, peak shaving, etc). Support: Victron support is excellent, if your problem can't be solved by the installer or the reseller it will get escalated to an R & D engineer (ie the guy who made the thing). Open source: Most non-software people might not care about this, but the protocols and much of the software is open source.
