April 3, 20197 yr You can use the Multi without a BMV. It has its own SOC tracking, and with a Venus device (CCGX or Venus-GX) the solar charger current is communicated to the Multi so it can track that too. BUT... a BMV is much more accurate, and especially if you're going to use a small battery bank, I really would advise that you get the BMV.
April 3, 20197 yr Just now, Mistral said: Ok thanks which BMV? Helps to know the difference. BMV-700 measures one battery, no more. BMV-702 has a secondanalog input that you can use for 1) measuring a second battery, eg a starter battery in a vehicle, 2) temperature sensor, or 3) midpoint monitoring. BMV-712 has everything the 702 has plus BlueTooth. Most people will go for the 702.
April 3, 20197 yr 55 minutes ago, Mistral said: Probably looking at Trojans if you guys agree? Would love lithium's but budget is tight.. If Trojans 6V or 12V - 6V the more popular? Trojans are good BUT: 1) Unless you go AGM, the others need to be in a ventilated space and watered and you need a BMV. Cost increases. 2) If you go 24v it saves a bit on the bank but then you must get a Multigrid for the Multiplus-II does not come in 24v, only 48v - MG is bit more than a MP-II so you win on the MP-II. 3) 4 x 6v T105RE's is a couple of thousand less than a 48v Pylontech bank - if you shop very hard - and you don't need a BMV so on 48v you win more. My guess, between a 24v MG with 4 x T105RE's plus a BMV it would be same or damn close to a MP-II with Pylontechs - and the Pylon's have better cycles. So best value for money, best future proofing, 48v Multiplus-II with a small Pylontech bank wins. 🙂
April 3, 20197 yr Author 1 hour ago, plonkster said: Helps to know the difference. BMV-700 measures one battery, no more. BMV-702 has a secondanalog input that you can use for 1) measuring a second battery, eg a starter battery in a vehicle, 2) temperature sensor, or 3) midpoint monitoring. BMV-712 has everything the 702 has plus BlueTooth. Most people will go for the 702. Thanks!
April 3, 20197 yr Author 51 minutes ago, The Terrible Triplett said: Trojans are good BUT: 1) Unless you go AGM, the others need to be in a ventilated space and watered and you need a BMV. Cost increases. 2) If you go 24v it saves a bit on the bank but then you must get a Multigrid for the Multiplus-II does not come in 24v, only 48v - MG is bit more than a MP-II so you win on the MP-II. 3) 4 x 6v T105RE's is a couple of thousand less than a 48v Pylontech bank - if you shop very hard - and you don't need a BMV so on 48v you win more. My guess, between a 24v MG with 4 x T105RE's plus a BMV it would be same or damn close to a MP-II with Pylontechs - and the Pylon's have better cycles. So best value for money, best future proofing, 48v Multiplus-II with a small Pylontech bank wins. 🙂 By the time I have paid for the Pylontech's I can afford half a panel!😀 So if I plead poverty and take AGM's can I use them with the Multiplus-II with a life expectancy of ..cycles? I originally planned to use the inverter by day and Escom at night to keep battery costs down.
April 3, 20197 yr 3 minutes ago, Mistral said: By the time I have paid for the Pylontech's I can afford half a panel!😀 24v Trojans are maybe 2-3k less than Pylon's BEFORE you add a BMV for wot, R3k to that? 48v Trojans are +-3-5k MORE than 2.4 Pylons. 3 minutes ago, Mistral said: So if I plead poverty and take AGM's can I use them with the Multiplus-II with a life expectancy of ..cycles? AGM and MP-II works well together. Cycles about 1600-1700 to 50% DOD, or +-4000 at 20% DOD / 80% SOC. 5 minutes ago, Mistral said: I originally planned to use the inverter by day and Escom at night to keep battery costs down. I'm with you on that one, Trojan batts, use them max 20% DOD to let them not stand there, the rest in case Eskom fails.
