April 11, 20197 yr I Have a pylontech us 2000 batt. I got a quote from a Comp. for a Narada Li_ion for about R10k can i just couple it to my 5k Axpert with the pylon?
April 12, 20197 yr 13 hours ago, Tokkiebod said: can i just couple it to my 5k Axpert with the pylon? You didn't say what model Narada battery you're considering. They make lead carbon batteries, for example. If it's a similar sized LFP battery like the 48NPFC50, then you might get away with it, with the hassles of different cabling, different monitoring, etc. Personally, I would not mix brands. The Narada mentions 54±0.5 V for charging; that's not quite compatible with the Pylontech, but it might be close enough.
