June 10Jun 10 A client of mine had someone install 2X 8kW inverters in parallel. The problem is that the slave unit trips after about 5 minutes of the system running, have run through all the connections and communication settings and everything is in order. What could be the issue that I'm missing?
June 18Jun 18 What brand are they?Is there a fault code (e.g. "F80") when the slave trips? Edited June 18Jun 18 by Coulomb
June 18Jun 18 Author https://acdirect.co.za/product/invt-8kw-solar-inverter-battery-combo-deal-1-x-invt-8kw-inverter-2-x-5kw-lithium-valley-lithium-ion-battery-8-x-ja-solar-550w-solar-panels/?srsltid=AfmBOopOb7n9Xm-plbJL93-8iS1FrhOGrjGIi1aQVeVDVXQq2UtGbUXdits exactly this one
