5 hours ago5 hr Hello Powerforum members,Hubble Energy will be sending me one Hubble Energy AM16+ (16.1kWh) and one AM5+ (5.12kWh) for extended real-world testing and review. These are part of their current LV Range which includes:AM-2 – Popular 5.5kWh 51V NMC battery 1C rating, proven long-term performer.AM-4 – Compact 2.56–2.75kWh 25.6V wall-mount battery with 1C rating.AM-5+ – 5.12kWh 51.2V LFP with built-in Cloudlink, 1C rating and RGB display.AM10+ – Larger 10kWh+ model in the + series with advanced features.AM16+ – High-capacity 16.1kWh floor-standing LFP with wheels, built-in Cloudlink and high discharge capability.S-100A – 12V 100Ah (1.2kWh) compact lithium battery.X-5+ (New X-101) – Newer generation Rack Mounted 5.5kWh model with updated features.X-101 – Established Rack Mounted 5.5kWh 51V model, widely used in hybrid systems.Note: Hubble Energy also has a very exciting HV Range, but this review will focus 100% on the LV Range especially for members who already own Hubble batteries or are considering them.Hubble Energy will also soon release the new AM-2+, which keeps the same NMC technology as the existing AM-2 models but adds built-in Cloudlink and several extra features. My Setup:Main system: Solis S6 8kW Pro Hybrid (master) with a Solis S6 6kW Pro seeing the 8kW as “grid”AC-coupled: Enphase micro-inverters + Solis S5 4.6kW grid-tied inverter on the Aux port of the 8kW2kW Wind turbine on the Solis S6 6kW MPPT in constant voltage modeSeparate Solis 5kW Off-Grid inverter for additional testingExisting battery bank: 7 × Hubble AM2 (mixed ages – oldest >5 years old)AM2 cycle counts right now:1411 | 1036 | 880 | 853 | 805 | 737 | 595 cycles Total bank health still at 99% – very impressive for the age mix.What I’ll be Testing:Daily cycling and performance of the AM16+ and AM5+ on the Solis S6 6kW and the 5kW Off-Grid inverterParallel operation between the new + series and my existing AM2 bank (old model compatibility is a big claim)Mixing different aged AM2 batteries and different capacities with the new unitsCompatibility with multiple inverter brands/configurationsCross-brand testing – insider info from a senior Hubble engineer says the new Plus range can work with almost any other battery brandFull use of the built-in Hubble Cloudlink (I have unit #388)I’ll also be highlighting the exciting new ergonomic and safety features:Wheels on the AM16+ for easy movementMagnetic panels that neatly hide all internal cablesFront-accessible BMS and critical components for simpler maintenanceActive cooling, fire suppression, and moreThe unlimited cycle warranty on these new models is particularly attractive and will be closely monitored during long-term testing.I’ll be doing a detailed initial short-term review followed by ongoing long-term data over the coming months. Expect real numbers on efficiency, temperature performance, charge/discharge behaviour, Cloudlink functionality, noise, installation, display readability, and real-world interaction with wind + AC-coupled solar.We will also speak nicely to Hubble Energy and ask if they can provide some products for a lucky draw / giveaway for Powerforum members.If you have any testing requests (particular charge profiles, high-load scenarios, Cloudlink screenshots, parallel comms behaviour, etc.), please reply in this thread. I’ll try to cover as many as possible.Product links:AM5+AM16+This should be a very thorough and transparent review for the Hubble community. Looking forward to sharing the results with everyone.Cheers, @Powerforum Store Hubble Energy AM5+ Brochure V1.2.pdf Hubble Energy AM16+ Brochure V2.3.pdf
