July 25Jul 25 I have tried different cable combinations, but I can't get the BMS to function, it keep giving me rttor 61.I made a cable tike the following example, still the same.Can it be the firmware, how do I check it and update if Necessary? Power Forum BMS Cable.docx
July 29Jul 29 On 2026/07/25 at 9:02 PM, AntonvdWest said:Can it be the firmware, how do I check it and update if Necessary?Yes, it could be firmware, especially display/comms (U2) firmware.Press up or down buttons on your display until you see a page with U1 or U2 followed by 4 digits. Note both of those and post them in a reply.If you are using monitoring software, it will have the firmware versions in there somewhere. Details vary with the monitoring software.
