Hello,
I have 5.12 kWh lithium batteries rated at 51.2 V / 100 Ah, but I am experiencing several problems with their BMS:
- The DIP switch addressing appears to be incorrect.
- The batteries cannot be completely shut down; they can only be restarted.
- The battery communication protocol sometimes stops sending data to the inverter.
- The battery voltage and SOC can drop to very low levels without following the inverter’s discharge control/command.
The batteries are currently running firmware version 15.53.
I would like to upgrade the firmware from version 15.53 to 15.58. Could you please confirm whether version 15.58 is fully compatible and safe for this battery/BMS model and whether the upgrade can be performed without causing any additional problems?
If version 15.58 is recommended, please provide me with the correct firmware file and the proper update procedure.
Thank you for your support.
23 minutes ago, Alternative energy enthusi said:
Hello,
Hello and welcome. What country are you posting from?
What is the make and model # of the batteries, and the inverter?
How do you know that the DIP switches are incorrect?
Is there no switch on the batteries? Even a soft switch? Can you share a photograph?
How do you know that the comms between battery and inverter are working or not working?
In a setup where there is BMS --> Inverter communications, the inverter obeys the commands of the battery BMS, not the other way around.
If the battery SOC drops too low, then the inverter is either not following the directive from the BMS to cease discharge, or the BMS has not issued it. The BMS can also issue a charge directive to the inverter, demanding that it charge the battery if it gets too low.
Please provide the make and model # of the batteries, and the inverter, so that people have the information that they need to assist you?
21 hours ago, Yellow Measure said:
أهلاً وسهلاً. من أي بلد تنشر هذا؟
For Yemen
ما هي ماركة وموديلات البطاريات، وما هو العاكس؟
Actually, I don't know the exact model of the batteries, but the inverter is a Sunsynk 8K Hybrid.
كيف تعرف أن مفاتيح DIP غير صحيحة؟
I need the program shown in this picture to solve the protocol problem.
ألا يوجد زر تشغيل على البطاريات؟ ولا حتى زر تشغيل ناعم؟ هل يمكنك مشاركة صورة؟
There is an RST button.
كيف تعرف ما إذا كانت الاتصالات بين البطارية والعاكس تعمل أم لا؟
The communication works, but what caught my attention is that sometimes the batteries stop sending information to the inverter.
في نظام توجد فيه اتصالات بين نظام إدارة البطارية والعاكس، فإن العاكس يطيع أوامر نظام إدارة البطارية، وليس العكس.
إذا انخفض مستوى شحن البطارية (SOC) إلى مستوى منخفض جدًا، فإما أن العاكس لا يستجيب لتوجيهات نظام إدارة البطارية (BMS) بالتوقف عن التفريغ، أو أن نظام إدارة البطارية لم يصدر هذه التوجيهات. كما يمكن لنظام إدارة البطارية إصدار توجيه شحن للعاكس، يطالبه بشحن البطارية إذا انخفض مستوى شحنها إلى مستوى منخفض جدًا.
Yes, it does not follow the commands properly, and a low battery voltage error appears.
يرجى تزويدنا بنوع وطراز البطاريات، وجهاز العاكس، حتى يتمكن الناس من الحصول على المعلومات التي يحتاجونها لمساعدتك؟
Actually, I don't know the exact battery model very well. However, I obtained a video from a friend of mine who passed away. He was an engineer and had the program that can configure the protocol correctly.
