August 5Aug 5 Hello everyone,I'm kindly asking for help once again.I believe someone in this group is using Solar Assistant, and I'm also hoping that someone has experience with Shoto 4.8 kWh 100 Ah batteries together with Kodak inverters.I would really appreciate some advice on two things:The correct inverter settings to make the best use of my solar system and reduce my electricity costs.How to correctly set up and configure my battery BMS through my Raspberry Pi 2 running Solar Assistant.My electricity bill is becoming far too expensive, so I'm trying to optimize my system as much as possible. I would sincerely appreciate any guidance or recommendations from someone with experience using a similar setup.Please refer to my previous post for the full details of my system.Thank you very much in advance.
