May 24, 20197 yr Hi all I have a 12kw off grid system installed, but my batteries only last about 5-6 hours, i have four 4,8kw (100ah ) 48v lithion ion batteries connected into the system My load during the evening runs at about 2,7kw Any sugestions? Thank you
May 24, 20197 yr That sounds about right? 4*4.8 gets you just shy of 20kwh. 6*2.7 gets you to around 17kwh. Sounds to me like you either need more batteries or less load? 🙂
May 26, 20197 yr A load management system is written into you future lol I have a 8800w usable system and pulling 1.5a it will last 20hrs. You are pulling 11a. Your inverter also use Watts to do its job. Is the 4.8kw down to 80% dod? The answer is a real Elon Musk. joppie of a few mw...
