Goodwe inverter wifi reload button.
Hi,
My wifi light is blinking indicating that wifi is not connected to the router.
I'm looking for the reload button on the inverter but cannot find it where the owners manual indicates it to be. Next to the wifi is a plate with a cable saying "meter".
Can someone help?
Is it necessary to reload inverter wifi?
If its only blinking, a restart of the unit should fix the problem.
Next to the wifi module is a second  rectangular cover, loosen the 4 screws, the wifi reset button is on the inside the machine next to the usb ports used for direct communication. Only reset as a last resort, after resetting, you will need to re-configure the wifi module.
How  old is this installation, and did you do this installation yourself? If you did, the Inverter as well as the wifi module needs a firmware update, without that update the wifi remains problematic. For updating your Inveter you will need a male to male usb cable.
