August 30, 20197 yr Battery drained all the way last night (RCD tripped) and system shutdown. Look at the picture - when will it pick up the loads again? When the battery reports 100%?
August 30, 20197 yr 15 minutes ago, deapsquatter said: Battery drained all the way last night (RCD tripped) and system shutdown. Look at the picture - when will it pick up the loads again? When the battery reports 100%? You are using ESS, right? What mode is is in? Optimised? Are you above the minimum SOC yet?
August 30, 20197 yr Author 3 minutes ago, plonkster said: You are using ESS, right? What mode is is in? Optimised? Are you above the minimum SOC yet? ESS, Optimised with Battery Life, Min SOC and Active SOC at 35% Edited August 30, 20197 yr by deapsquatter
August 30, 20197 yr 4 minutes ago, deapsquatter said: ESS, Optimised with Battery Life, Min SOC and Active SOC at 35% DM me your VRM url.
