August 31, 20197 yr Hi All expert Sorry for bad english language. 5 year ago I bought Omnik Hybrid inverter model Omnikhyd-3.0k-TL from some one , got only inverter no software no communication cable no warranty . I install it only on grid no battery and work well. Now I want to add new battery backup and setup battery parameter inverter I try to connect it with SolarPower software via rs232-usb cable but not work no response from it. could anyone please help me Thank you
August 31, 20197 yr Author 13 hours ago, Coulomb said: The communications happen at 2400 bps. You appear to be using 9600 bps. Already try at 2400 bps or higher. no differential no response
September 1, 20197 yr Ah. Thinking about it, SolarPower would set the bit rate anyway. Not all USB to RS232 adapters seem to work with Voltronic Power inverters. The know-good ones seem to use a PL2303 chip; there is a chip checker in this post.
September 21, 20196 yr Author On 2019/09/01 at 9:49 AM, Coulomb said: Ah. Thinking about it, SolarPower would set the bit rate anyway. Not all USB to RS232 adapters seem to work with Voltronic Power inverters. The know-good ones seem to use a PL2303 chip; there is a chip checker in this post. Today I try again with RS232 to USB PL2303 RA chip. as expected no response from inverter
