Omnik hybrid inverter communication problem
Hi All expert
     Sorry for bad english language.  5 year ago I bought Omnik Hybrid inverter model Omnikhyd-3.0k-TL from some one ,  got only inverter no software no communication cable no warranty . I install it only on grid no battery and work well.  Now I want to add new battery backup and setup battery parameter inverter I try to connect it with SolarPower software via rs232-usb cable but not work no response from it.  could anyone  please help me
Thank you
13 hours ago, Coulomb said:
The communications happen at 2400 bps. You appear to be using 9600 bps.
Already try at 2400 bps or higher. no differential no response
On 2019/09/01 at 9:49 AM, Coulomb said:
Ah. Thinking about it, SolarPower would set the bit rate anyway.
Not all USB to RS232 adapters seem to work with Voltronic Power inverters. The know-good ones seem to use a PL2303 chip; there is a chip checker in this post.
Today I try again with RS232 to USB PL2303 RA chip. as expected no response from inverter
