April 30, 20206 yr Author thanks a lot guys, I answered your messages. Unfortunatelly I have problem to read device SN started with 96... I have few issues. Does anybody have SN started 96... and it's working in application?
May 3, 20206 yr Hi Stef1985, your device does not work with the buffy APP? Or even with the power-datacenter.com?
May 30, 20206 yr hola tengo problemas al agregar mi dispositivo en la aplicación, tengo mi dispositivo agregado a http://power-datacenter.com/ y funciona correctamente. pudieran ayudarme, gracias
June 12, 20206 yr On 2020/04/30 at 6:37 PM, buffy said: thanks a lot guys, I answered your messages. Unfortunatelly I have problem to read device SN started with 96... I have few issues. Does anybody have SN started 96... and it's working in application? Hello i download this app solar power, but do not working, give me error sn. Sn is correct. Do you can help me? thank you
June 12, 20206 yr Author 11 minutes ago, Josearaujo10 said: Hello i download this app solar power, but do not working, give me error sn. Sn is correct. Do you can help me? thank you Hello, I tried your SN and there is no data. I'm not sure why. Do you have new device? How long do you send data to this server? Sorry for this issue. i worked with my data and it works ok.
June 12, 20206 yr 4 hours ago, buffy said: Hello, I tried your SN and there is no data. I'm not sure why. Do you have new device? How long do you send data to this server? Sorry for this issue. i worked with my data and it works ok. Yes is new, it’s only conect to the server 24h ago. i send you one PM mensage thank you
July 20, 20205 yr Hello, I have an MPP SOLAR model MPI 10K three-phase hybrid inverter. I installed the SNMP Web Pro card in my UPS. The SOLAR POWER PRO application is used in Windows 8. Unable to send my production data from my inverter to the POWER-DATACENTER website. I'm sure I made a mistake below in the settings ! HTTP server: http://power-datacenter.com:80/cmmq/datacenter/fw/wifi Where is my error by the HTTP server POWER-DATACENTER.COM ? I want to use the SOLAR POWER app on my iPhone, but without your help, I couldn't do it! Many thanks in advance. Peter
July 21, 20205 yr Hello , The configuration for the POWER-DATACENTER.COM is not OK ! Do you have the correct POWER-DATACENTER.COM HTTP Server to send my data to this site ? Thanks in advance. Have a good day
August 16, 20205 yr hi I have replaced my old inverter with new hybrid on my old one app was working perfect new one gives me error S/n error check later i can see data on the web but not in app the S/N is 96132006100775 Thanks in advance
August 17, 20205 yr Author 15 hours ago, cobser said: hi I have replaced my old inverter with new hybrid on my old one app was working perfect new one gives me error S/n error check later i can see data on the web but not in app the S/N is 96132006100775 Thanks in advance sorry, not working also for me I'm not sure guys, why some SN works and some not... I didn't find solution of this issue.
August 19, 20205 yr I have tried both on ios and android the same issue it does not make sense the data is on server but it can not reach (Fetch) because of the s/n Edited August 19, 20205 yr by cobser
November 16, 20205 yr hi buffy your app is working fine with effekta m1-4000 48V Inverter (tested 11/2020) with WLAN-Box can i ask you how you get the data from http://www.power-datacenter.com/cmmq/dataCenter ?? i want to use the data in my Node-Red V1.2.3 Server on Synology DS1515+ but dont now how?? best regards olaf
January 31, 20215 yr On 2020/08/17 at 2:21 PM, buffy said: sorry, not working also for me I'm not sure guys, why some SN works and some not... I didn't find solution of this issue. On 2020/11/16 at 8:37 PM, commander-bln said: hi buffy your app is working fine with effekta m1-4000 48V Inverter (tested 11/2020) with WLAN-Box can i ask you how you get the data from http://www.power-datacenter.com/cmmq/dataCenter ?? i want to use the data in my Node-Red V1.2.3 Server on Synology DS1515+ but dont now how?? best regards olaf Would also love to be able to do this, please
March 17, 20215 yr Hallo @Buffy I am interested in the iOs app without ads for my Mecer inverter - I have two. Can the app support more than one setup (work and home)? Pleas let me know where I can get the App. Thank you SP
April 20, 20224 yr Hi Buffy, today the website http://power-datacenter.com is not working ? Do you have any idea? Maybe it was changed to https:// Thanks for your help Yesterday it works fine
January 11, 20233 yr Good to see your excellent effort for solar monitoring. but it didn't work on my LG mobile android version 6..... Can u modify Watchpowerwifi which majority of the Chinese invertors / data loggers support... Do check it out... i am currently using Dessmonitor.com for PC viewing and watchpowerwifi for android mobile
October 24, 20232 yr Hello, im new on this forum. I have Infinisolar 10k hybrid with wifi card, it is configured with power-datacenter, all readings on web page are ok. I have also SolarPowerMonitor app on IOS and android, configured to read my inverter serial from power-datacenter, but the readings are unreal on both versions android and ios. Fo example during production solar panels is ---, voltage is 2355V, battery is not connected but app show 2450% charge, AC output shows approximately 25% real value. I would like to use version without adds if it is possible. My inverter SN is 96161605100XXX, it is working in GridTie mode . Please help,
