January 15, 20206 yr Hi Everyone, I'm easing into having backup power for when Eskom feels like having loadshedding. Currently I have a Eaton 2000va UPS running my external Wireless equipment that provide my internet. It runs for about a hour and then cuts out which has been ok but the family wants to be able to watch Netflix for the full duration of Loadshedding 😁. I admit its not the best solution but its worked for our need thus far. So I started gathering a few second hand equipment and so far i have the following: 1x RCT-Axpert 3K inverter charger 4x CSB HRL 12390 batteries Relevant cables for batteries DB box to house fuses and circuit breakers I still need to get the following: 2x 100A fuse and holder Circuit breaker for AC input and Output(not sure if i need this or not) battery DC Isolater switch for Pos(+) and Neg(-) (uncertain what switch i should get) This will not be tied into the circuit of the house so I will not need to fiddle with the current DB. For some it might seem to be a bit elaborate just to have internet/network while loadshedding but the hope is to be able to run some other things as well in the future and also, inverter allows for Solar input so that's also a option to explore. Do I need the circuit breakers? If so what amperage? what isolater switch do i get?
January 15, 20206 yr 2 hours ago, uberlegen said: 2x 100A fuse and holder Circuit breaker for AC input and Output(not sure if i need this or not) Yes, you need them. It will work without them, the same as you can still get to your destination in your car if you don't wear a seat belt, but it's a really good idea to have them. Quote battery DC Isolater switch for Pos(+) and Neg(-) (uncertain what switch i should get) You can get a fuse holder that is also an isolator. Quote circuit breakers? If so what amperage? It will be in your inverter's manual. Looks like it will be 32 A for the input breaker, you could use 16 A for the AC-out.
January 15, 20206 yr Author 1 hour ago, Coulomb said: Yes, you need them. It will work without them, the same as you can still get to your destination in your car if you don't wear a seat belt, but it's a really good idea to have them. You can get a fuse holder that is also an isolator. It will be in your inverter's manual. Looks like it will be 32 A for the input breaker, you could use 16 A for the AC-out. Thanks I will have a look for the Fuse Holder/Isolater type This is the sticker on the side of the Inverter
January 15, 20206 yr If its literally just for routers why don't you run the gear directly off a battery? I do that and can run my internet off grid for probably 3 days, I have 2 x 12V 35AH batteries with a Victron Charger and a DC-DC 12-24V converter for my 24V "core router" my setup..... Mikrotik 960PGS (12V) as main router, POE out powers 2 Mikrotik CAP ceiling mount AP's (12V) for internal wifi, 1 x Mikrotik RBD52G router (12V) for entertainment area, 1 x Mikrotik RBSXT (12V) which I'm using for a PtP wireless link for my cameras, Nokia fibre ONU (12V) supplied by Vodacom. I also have a 12V DC to 5V DC USB adapter to power my Raspberry PI which I use for home automation. The routers each draw around 200ma, I'd guess total draw to be around 1.2A at most. You could build a system like this quite easily for around R2K and it will keep your 12V gear up far longer than a UPS or inverter, rather use the inverter & UPS for 220V devices.
