February 18, 20206 yr Hi There, At present I have (9) 255W Solar panels connected to my Inverter, I would like to add 3 more panels which are 265W as I am unable to obtain 255W panels. My Installer is saying that he will have to run a 2nd set of cables as my present cables will not handle the current of all 12 panels, so a 2nd set of cables will reduce the Amps. Is he correct in saying so? I really did not anticipate the extra cost of cabling as I already had to purchase mounting rails and clamps which I have mounted already in preparation to connect. Inverter Specs: Inverter Mode Rated Power 5000VA/4000W DC Input: 48VDC, 93A AC Output 230VAC ,50Hz, 22A 1 AC Charger Mode AC Input 230VAC, 50Hz, 35A DC Output 54VDC MAX 60A, Default 30A AC Output 230VAC, 50Hz, 22A Solar Charge Mode Rated Current 60A System Voltage 48VDC Min Solar Voltage 40VDC Max Solar Voltage (VOC) 145VDC I'm no electrician but I try and need to ask before I spend
February 18, 20206 yr Hi.. I assume that you are referring to the cables from the panels. You should already have 3 sets of cables going into your combiner box. It's wiser to add the fourth set and keep your 4 banks of 3 panels on their own wires and fuses. Just cleaner and easier to troubleshoot if you have issues.
February 18, 20206 yr Author OK Cool, Thank for replying, yes it makes sense should issues arise. I have 3 banks of 4 panels with one on its own which will have an addition of 3 more panels to complete the 4th bank. So, good to go then. Thank You SagieN
