INVERTER OUTPUT 0V
39 minutes ago, Clifford Mwiza said:
My 3kva axpert inverter output is going from 230 to 0V in less than a second when turned on.
what could really be the problem?
Perhaps you have power saving turned on? Setting 04. I prefer SDS (disable). Otherwise, add a load of at least 100 W and see if it stops pulsing (assuming that it is pulsing on and off).
