February 26, 20206 yr Ello, I saw @plonkster post a recommendation for this victron multiplus but I've always wondered, looking at the connections: I pressume you'd get a cable with the inverter to plug into the AC IN connector, but how do you connect the AC OUT? and do you hook it up to your DB or do you put a multiplug on it (because it doesn't make alot of sense to me to hook e.g. a 500W inverter to your DB) ? -G-
February 26, 20206 yr 3 hours ago, gallderhen said: I pressume you'd get a cable with the inverter to plug into the AC IN connector, but how do you connect the AC OUT? and do you hook it up to your DB or do you put a multiplug on it (because it doesn't make alot of sense to me to hook e.g. a 500W inverter to your DB) ? You get plugs with the inverter for both the input and the output. You can hook it into the DB if you really want to, maybe just sub circuits. See this install for example.
