Guest Posted March 11, 2016 Share Posted March 11, 2016 Looking for a solar panel mounter that understands wind loads, metal sheet roof etc. Can someone please refer me to someone that does not cost an arm and a left t... Quote Link to comment Share on other sites More sharing options...
MaurizioZA Posted March 11, 2016 Share Posted March 11, 2016 uhmm ... I doubt you will find such a person in CT ! Quote Link to comment Share on other sites More sharing options...
Guest Posted March 12, 2016 Share Posted March 12, 2016 Oooo, they are here, trust me, just hiding. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted March 12, 2016 Share Posted March 12, 2016 I wouldn't skimp too much on this part, especially in Cape Town. How many panels do you have, and what type of roof? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 12, 2016 Share Posted March 12, 2016 Nope, I have not. Had aluminium frames custom made to fit on the roof sheets. Panels are protected from the full force of the Northeaster behind the main roof ridge. They are never in shade. Want to check a 200w panel that it is properly fixed, then have it mounted back on the roof and IF it passed the test, connect the 2 x 200w in series. The 3 x 310w panels, want them checked that they are as expected. Add another frame for a 4th 310w panel IF the controller can handle it. I will concede the installer may supply it. In both cases check the wiring AND shorten it. MAYBE into a combiner box. On these roof sheets: http://www.diamondek.co.za/ Good news is, where the panels are, the roof is quite flat. And then earth the panels. Quote Link to comment Share on other sites More sharing options...
subok01 Posted March 13, 2016 Share Posted March 13, 2016 Do yourself a favour and contact MLT Drives in CT. They match your requirements. Sent from my SM-N910H using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2016 Share Posted March 13, 2016 Thanks Subok01. Been there, done that. Was too small for them. If I do not come right, will try them again. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted March 13, 2016 Share Posted March 13, 2016 On 3/12/2016 at 9:39 PM, The Terrible Triplett said: Nope, I have not. Had aluminium frames custom made to fit on the roof sheets. Panels are protected from the full force of the Northeaster behind the main roof ridge. They are never in shade. Want to check a 200w panel that it is properly fixed, then have it mounted back on the roof and IF it passed the test, connect the 2 x 200w in series. The 3 x 310w panels, want them checked that they are as expected. Add another frame for a 4th 310w panel IF the controller can handle it. I will concede the installer may supply it. In both cases check the wiring AND shorten it. MAYBE into a combiner box. On these roof sheets: http://www.diamondek.co.za/ Good news is, where the panels are, the roof is quite flat. And then earth the panels. Have a look at these brackets: http://www.lizardsouthafrica.co.za/pv-mounting-systems-products/ They are SABS approved and the guys assured me it will work in the Cape as well. My boet stays in Brackenfell, still need to go put some PV on his roof sometime. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2016 Share Posted March 13, 2016 Here is the exact roof we have: http://www.diamondek.co.za/, supplied by Youngman in Cape Town. They have tested those Kliplock mounting systems on their roofs, the MK005 and 6. After their tests, they advised me not to use them. Has to do with the sheets clipping onto the batons, where the panels can lift the roof sheets under certain circumstances. Yes, I had frames made that clamped on, other frames where fastened through the sheets. Trick is to now to find the bloody batons / trusses under a solid roof with no crawl space where if you make a mistake and it leaks, to fix that will be a real challenge, to say the least. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted March 18, 2016 Share Posted March 18, 2016 Did you come right? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2016 Share Posted March 18, 2016 Nope. Still waiting for one installer to visit when he has time, as it is not a life and death situation. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted March 18, 2016 Share Posted March 18, 2016 1 hour ago, The Terrible Triplett said: Nope. Still waiting for one installer to visit when he has time, as it is not a life and death situation. Pity you're so far, I'm in JHB, although I need to goto CT sometime to go help my boet setup his inverter, might come and do your installation as well if you haven't been helped yet. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2016 Share Posted March 18, 2016 3 minutes ago, SilverNodashi said: Pity you're so far, I'm in JHB, although I need to goto CT sometime to go help my boet setup his inverter, might come and do your installation as well if you haven't been helped yet. I will appreciate. Keep me posted on your movements, if I am not sorted by then. Quote Link to comment Share on other sites More sharing options...
