March 31, 20206 yr Hi All I am new to the forum and I was wondering whether you could assist me. Has anyone experienced the situation where the SOC on your Lithium battery is gradually dropping? I have a 48v 100ah Narada Lithium battery that used to be connected to a Mecer Axpert 5kva inverter. The problem started when I changed inverters to a new Sunsynk 5KW variant. The Narada battery is not one of the batteries compatible with the Sunsynk using a RJ45 cable link to interface the battery management system on the inverter. On advice from the suppliers of the inverter it has been set up as a lead acid battery. Float and charge voltage settings in new inverter are the same as they were in my old Axpert and also as per the battery user manual. 52 V float and 54V charge. The voltage on battery and inverter correspond. Any ideas to rectify this problem?
