May 5, 20206 yr Good day Hope someone can help, i need to install 2x 5kw king inverters in parallel with 30 x 320W JA solar panels,they want to add Pylon batteries later on , can i use this inverter as a GRID TIE inverter? I did see that on setting (1) that it have "SUB" and on setting (5-battery settin) a setting that says "SOL" it does not show in the manual, so i don`t know if it a type of battery like the setting "PYL" that is for Pylon or if it is for Solar. I will really appreciate if someone can assist me in this regard Thank you in advance Edited May 5, 20206 yr by Jurgens
May 5, 20206 yr 3 hours ago, Jurgens said: can i use this inverter as a GRID TIE inverter? No it does NOT feed in to the grid (classified as off grid but does however do bending in with the grid) 3 hours ago, Jurgens said: I did see that on setting (1) that it have "SUB" 1st Solar 2nd Utility than 3rd battery 3 hours ago, Jurgens said: setting (5-battery settin) a setting that says "SOL" Means charging source Solar only
May 5, 20206 yr 4 hours ago, Jurgens said: 30 x 320W JA solar panels If I'm not mistaken max it will only be able to take 12 panels on each inverter (3series and 4 parellel) so 24 panels in total Edited May 5, 20206 yr by Quat Allah As Shams
May 5, 20206 yr 4 hours ago, Jurgens said: Pylon batteries later on They work well but IMO it would be best to get Pi with ICC and pylontech communiction cable for ICC to get your systems batteries SOC,etc working perfectly www.iccsoftware.co.za Edited May 5, 20206 yr by Quat Allah As Shams
