July 14, 20206 yr Has anyone have any experience in getting a VE.Can device running on the Pi version of VenusOS? I see that there are a few options here to connect CAN interfaces with the Pi. Anyone know if it works well and is worth the effort?
July 14, 20206 yr Cheapest option is a MCP2515 "hat" (called the CanBerry in that document). The device tree overlays are already on the boot partition and can be loaded in the usual manner, by listing them in config.txt. In my opinion, the total cost of vedirect-usb cables for the solarchargers plus the mk3 dongle plus the CAN-hat plus a nice case... puts you pretty close to just buying a Venus-GX.
July 15, 20206 yr Author Thanks @plonkster . The MCP2515 looks like a option. I am already to far down the rabbit hole. They rPi was laying around, begging to be used for something and I needed the MK3 to be able to set the custom charge settings for my DIY battery. I was not planning on using any CAN devices, but looking at perhaps adding and second hand BlueSolar Can charger to the mix for my ESS setup.
July 16, 20206 yr Author Thanks @SolarNoob I was looking at that hat last night, but they were sold out. Great to see they got stock now. Did you had to add the dtoverlay line in your config.txt or was the driver already loaded in the VenusOS?
