July 22, 20206 yr HI all I recently installes 2x5kw Must inverters in parallel and 18 panels with 8 bateries I monitor my systwm with wi-fi rtu. Do you guys know the Must inverters? And I have 2 wifi monitors up, one for each inverter. The system only shows me one reading and does not combine the reading. Any advice. Thx
July 22, 20206 yr So are these Axpert clones / workalikes? 9 hours ago, louia said: The system only shows me one reading and does not combine the reading. I don't understand your question; what do you mean by "readings" and combining them how.
July 23, 20206 yr Author 9 hours ago, Coulomb said: So are these Axpert clones / workalikes? I don't understand your question; what do you mean by "readings" and combining them how. The system is not giving me the 2 inverter readings on the app. For example: Inverter 1 generates 3kw energy at 13:00 Inverter 2 generates 1.2kw at 13:00. On the app it only shows 3kw that is been generared and not 4.2kw
July 23, 20206 yr Do you see the two inverters in your app? Is the app called Watchpower? As a point of interest, especially if you only see one serial number, is it a string of 5's and 3's, such as 55355355... ? Some clones have the same serial number come out, so the monitoring software can't distinguish the two inverters, so you only get one inverter's measurements. Quote And I have 2 wifi monitors up, one for each inverter. I believe that an Axpert system would only need one WiFi monitor or RS-232 connection; the master can see the most important measurements for all the slaves. But I've not seen the Watchpower (for Axperts) app in action. Edited July 23, 20206 yr by Coulomb
