August 14, 20206 yr @plonkster, This is probably right up your street. My BMV drops out of comms with the Venus GX every 2 weeks or so, sometimes it recovers, sometimes not. It always recovers when I reboot through VRM. ( Which means I constantly have to keep an eye on things) It is a powered USB hub, but it is also an el-cheapo. I do have the option of Ve-direct straight into the Venus with this system. I also have procured an expensive powered industrial Startech USB hub and a Cerbo for another system. In that system I will be forced to use a USB hub for somethings due to the number of VE devices. I interested in your thoughts/comments about possible causes and how you would prioritize the existing VE ports over the USB hub.
August 14, 20206 yr 8 minutes ago, phil.g00 said: It is a powered USB hub, but it is also an el-cheapo. Had the same issue till i replaced the el-cheapo, problem free for 2 years after that till the day I replaced my Lead Acids with Pylons. 8 minutes ago, phil.g00 said: I do have the option of Ve-direct straight into the Venus with this system. I would recommend this option if one of the VE-Direct ports are free.
August 14, 20206 yr Usually you can get some clue by looking at the output of /data/log/messages, or by just dumping the kernel log ring with the dmesg command.
