September 4, 20206 yr I need to understand how to config the Dyness / Pylon Tech Lithium batteries when using 2X inverters in Parallel. I understand how to do the normal GEL batteries but what about the lithium battery packs? How do one connect them for battery sharing or should the be on their own setup to each inverter? 2X Battery packs to each inverter for instance? Any manual for this should be nice.
September 5, 20206 yr 22 hours ago, FrancoisHorn said: using 2X inverters in Parallel. You didn't say what sort of inverter. Axperts for example MUST be connected to the same battery. 22 hours ago, FrancoisHorn said: Any manual for this should be nice IF you're using an Axpert, this parallel guide manual would help.
