Pylontech Communication cables
I have pylontech lithiums batteries
Need to know which communication cable is used to connect batteries with each other via link ports
2nd which cable is used to connect batteries with inverter i.e cable sequence 1-3, 2-5, 3-1, 5-2
Its a short cable that comes with pylontech in the box (link port1 from master to link port 0 on secondary and so on)
Please give more information as to what type of an inverter (make,model,etc) you have
Edited by Quwatush Shams (Suly)
When I connect batteries with inverter via above cable , battery sign keep blinking , not take output load
Kindly confirm cable wire sequence is correct
The flashing battery icon indicates that the battery is communicating. Nothing wrong
Bloubul7 thanks for replying
Actually battery icon keep flashing and inverter not working properly gone to line mode and again battery mode and so on
Setting are dip switch 1000 on both batteries
Quwatush Shams (Suly) thanks for replying
Actually I buy batteries from my friend so that cable is missing
Only I need is sequence of pinouts if you send me pictures of cable it will helps I make same Cable myself
The cable from the inverter must go to the RS232 port on the master battery.
First test the inverter with only one battery connected and see if it communicates correctly
Edited by Bloubul7
  • 2 years later...
Hey guys.
I have a similar problem and hoping you can help me out.
I bought a setup from a family member and in the getting it to me part. The batteries are pylontech 2000b
The short cable that goes from lan of battery A to battery B didn't make it in the move.
Is it a standard lan cable? Or something custom?
