Battery Usage
I have 4 x Vision AGM 200AH batteries.
My usage is approximately 500 watts consistently.
For how many hours would I expect my batteries to run before I reach my cutoff point of 46 volts which I have set on my inverter?
Many Thanks
Subject to correction please, just trying to figure this out for myself also.
P = V x I
500W = 48 x I
500/48 = 62.5 amps draw from a 200Ah battery bank.
So 200Ah / 62.5 amps draw = 3.2 hours
But then then it is completely discharged. So for 46V (and here is where I fall out of the bus lol) one must figure out what the state of charge is of the battery.
According to Uncle Google, at 46.4 Volt your battery is 90% discharged. Only 10% remaining thus.
And you do not want to be doing that to AGM's or Gel batteries.
P = V x I
500W = 48 x I
Hi Swartkat
Watts = V x A
Thus, he has a potential of 48V x 200ah = 9600Wah, but at 50% DOD that just gives him usable 4800Wah. If we devide this by 500W, it will theoretically give him the 9 hours I stated. If I am not maybe missing something here
Here I need to be corrected, hopefully someone here with more knowledge will help. But under load, 50% SOC will be close to 46V. If you take the load off, the voltage will probably shoot up to 48V again, which is basically 50% SOC without load.
This is what I got from google.
50% SOC will be 48.8V
State of Charge (%) 12V 24V 48V
100 12.83 25.66 51.32
90 12.72 25.44 50.88
80 12.60 25.20 50.4
70 12.47 24.94 49.88
60 12.34 24.68 49.36
50 12.20 24.40 48.80
40 12.06 24.12 48.24
30 11.91 23.82 47.64
20 11.76 23.52 47.04
10 11.61 23.22 46.44
Swartkat, yes I agree with those figures, but Voltage under load will read lower if I am right, and that would be the voltage the inverter uses to determine when to switch back to utility
So what I am basically saying, voltage on a battery not connected to anything will be higher than if it was under load. Same thing as you will see with your panels, no load, high voltage, the higher the load gets, the lower the voltage gets
