EngHomam Posted November 2, 2020 Share Posted November 2, 2020 Dears , I hope to get the firmware of Infini V to fix some problem during parallel like grid charge . I connect 3 inverter in parallel to get 3 Phase The first- second inverter have firmware 51.90 the third inverter has firmware version 52.30 we need to use same firmware for all inverter to stability So Please I need firmware with any version 52.30 , or 52.40 or 51.90 to update all inverters. Best regards. Quote Link to comment Share on other sites More sharing options...
razmasoom Posted November 9, 2020 Share Posted November 9, 2020 https://ostrovni-elektrarny.cz/?podpora This may help you. Coulomb 1 Quote Link to comment Share on other sites More sharing options...
EngHomam Posted November 9, 2020 Author Share Posted November 9, 2020 Thanks , But the site hasn't any firmware for Infini Solar V 5Kw . Quote Link to comment Share on other sites More sharing options...
Coulomb Posted November 11, 2020 Share Posted November 11, 2020 (edited) On 2020/11/10 at 12:08 AM, razmasoom said: https://ostrovni-elektrarny.cz/?podpora This may help you. Ah! Thanks for reminding me about this site; I hadn't looked there for over a year. I managed to scoop three recent firmware files from there: * VM III main firmware version 91.20; this appears to be the one with recent BMS support * Removable Display firmware version 02.60. I haven't looked at this yet, but on the surface it seems to be at least 2 major revisions higher than 02.49. I assume that this would be usable by Kings as well as VM IIIs. [ Edit: I'll be checking that in due course. ] [ Edit: It does seem to be King compatible so far. ] * Axpert Max 7200 W main firmware version 90.11. Edited November 11, 2020 by Coulomb Quote Link to comment Share on other sites More sharing options...
