axpert inverter and pylontech
Dear all , I have an axpert mecer 5kVA/5kW inverter and 6x pylontech us2000 installed for a client. The batteries are fully charged but the inverter is displaying 50% and still charging. What could be the problem?
The inverter reports SoC based on voltage and is designed for Lead not Lithium. Doesn't matter much as it doesn't do anything with SoC. All settings work on voltage.
You mention it's charging. I assume the light is just flashing now and then. What is your bulk/float charge voltage setting?
