Prowess MPS 5kVA Inverter
Hi folks,
Any ideas please.
I have a 5kVA inverter operating perfectly without solar input. I have now connected 2 strings of 3 x 390w panels.
The inverter is picking up +-130v which is perfect, but only 30-40w from the panels array.
What could be the problem?
[ Edit: Please pardon my manners. Welcome to the forum! ]
I'm assuming that the prowess inverter-chargers are rebadged or cloned Axpert MKS models. If not, nothing I say below applies.
Oh dear. See below.
Quote
No, 130 V is 15 V more than the upper range for MPPT operation.
Quote
It could be that you don't read my signature 😉
390 W panels are likely made up of more than 72 cells, and 3S of 72-cell panels is already too much for 145 V absolute max solar charge controllers. Even if you generate a little power at that high a voltage, the solar chargers overheat and cut back power after a short time.
You should rewire the panels as 2S3P. Perhaps just try 2S on its own to convince yourself that it's worth the effort.
If it's actually a clone, then all bets are off. Perhaps you could post a photo of the barcode sticker on the side of your inverter-charger (if any).
