Solar size & capabilities
Will i be able to add my swimming pool pump during the day onto my solar set up below. Note that i have a 5kva Growatt inverter. only the refrigerator and tv runs most of the day. will the load be comfortable to run on my inverter or must i add more panels?
What size pool pump? 0.75kw pump should be able to run on there without needing more panels. You might have issues if you decide to switch on both the microwave and dishwasher at the time the pool pump is running.
