Mr sujee
Hi all
I have an issue with the sunsynk 5kw inverter , we fitted in 7 panels with 2 us3000 pylontech batteries
it’s setup so that if there is enuf power for the load, the balance of power from pv will be sent to the non essential or grid , we have also installed the ct clamp to avoid power going out , it worked perfectly fine for the first 2 days , however on the third day the prepaid meter keeps tripping
what could possibly be the fault?
12 hours ago, Aslamsujee said:
Hi all
Can you share a pic of your settings page. The one where you set the time off use and zero export limits.
