March 24, 20215 yr Hello All I have installed a Sunsynk inverter and am struggling to connect the wifi logger to my network. I registered a plant and added the logger with its serial number. I can't find where to setup the network. The manual indicates go to "Plant Details"-"Device List", find the target SN then click "networking". I have no "networking" tab to select. This is on the webpage where the plant is setup. Can anyone help?
March 24, 20215 yr 1 hour ago, TonyH said: Hello All I have installed a Sunsynk inverter and am struggling to connect the wifi logger to my network. I registered a plant and added the logger with its serial number. I can't find where to setup the network. The manual indicates go to "Plant Details"-"Device List", find the target SN then click "networking". I have no "networking" tab to select. This is on the webpage where the plant is setup. Can anyone help? I don't think you can do it on the website. You will need to use one of the Solarman apps on android or iOS.
March 24, 20215 yr Author Hi All, I have managed to come right. I first had to configure onto my android phone. Once the phone established the router and logger connection all started to work. The webpage is also showing data now even with the phone off. Thanks for the answers
March 25, 20215 yr Author Here is the wifi setup which should be easily available. wifi data logger configuration.pdf
January 19, 20233 yr Hi I have replaced an old data logger wifi200 to this LSW-3-C and can't connect. to my wifi? not all the lights are on ready has a slow on and off light.. comms has a constant light on and net has no light on can anyone help me please.
