March 27, 20215 yr Good day technical support team. Please kindly advise. What does the regulations say about the size of wire you can use. My inverter is located 13meters away from my DB. Can I use 2,5mm cable instead of 4mm from my DB to the inverter, and from the inverter back to my DB. I won’t be putting too much load, it’s only for lights and 3 plugs. Is 2,5mm cable qualify me to get COC. thank you In advance from Jabu. Edited March 27, 20215 yr by Jabu
