Deye 5K 2xMPPT/PV
I'm not sure if I have a faulty unit... Because of roof space we installed 2x rows of solar on the roof
PV1: 5x panels
PV2: 4x panels
Originally they were all going to be in series with one set of PV cables, now there are 2x sets coming from the roof and onto PV1 and PV2 respectively.
Both sets give proper voltage (at +/- 8am 170V & 180V)
When I connect PV1 to PV1 on the inverter it reads
PV1: 170V
PV2: 5V
When I connect PV1 to PV2 on the inverter it reads
PV1: 5V
PV2: 170V
When I connect PV2 to PV1 on the inverter it reads
PV1: 180V
PV2: 5V
When I connect PV2 to PV2 on the inverter it reads
PV1: 5V
PV2: 180V
Is there a setting I need to enable in the inverter to enable both PV1 and PV2?
Thanks in advance!
Rookie Mistake... the ferrule inside the MC4 connector wasn't all the way in
New multimeter switches on the display from V to mV and you can't easily see the "m"... so 160V and 160mV looks almost identical!
Nothing to see here!!
