May 20, 20215 yr I have three SunSynk 8KW inverters. They are running independently. One for each phase of my home. I then have a 5.12KWh SunSynk battery per inverter/phase. These can only discharge at about 2.5KW. Currently there is one battery per inverter. Can I create a bank using the three batteries and connect this bank to each inverter? In theory the bank could then discharge at 7.5Kw. If this is possible how does charging of the batteries work? Do all three inverters charge the bank or is this left to only one device?
May 20, 20215 yr 3 hours ago, Brettsco said: I have three SunSynk 8KW inverters. They are running independently. One for each phase of my home. I then have a 5.12KWh SunSynk battery per inverter/phase. These can only discharge at about 2.5KW. Currently there is one battery per inverter. Can I create a bank using the three batteries and connect this bank to each inverter? In theory the bank could then discharge at 7.5Kw. If this is possible how does charging of the batteries work? Do all three inverters charge the bank or is this left to only one device? Hi Brettsco Please can you post a pic of your installation.
