June 8, 20215 yr HI How can I download the Firmware for the Axpert MKS 1KVA/1KW 12 volt from voltronicpower.com , or is there another source to download the Firmware for these device or Voltronic Devices? Thanks for your help,
June 8, 20215 yr 4 hours ago, mho_01 said: How can I download the Firmware for the Axpert... You can't. Occasionally there will be firmware for 5 kVA models and above on forums like this; for 1 kVA models, I don't think I've ever seen one. You will have to ask your reseller, and you'll need a good reason.
September 8, 20214 yr On 2021/06/08 at 1:01 PM, mho_01 said: HI How can I download the Firmware for the Axpert MKS 1KVA/1KW 12 volt from voltronicpower.com , or is there another source to download the Firmware for these device or Voltronic Devices? Thanks for your help, i also need you to share me with
September 8, 20214 yr On 2021/06/08 at 4:01 PM, mho_01 said: Firmware for the Axpert MKS 1KVA/1KW 12 volt... On 2021/06/08 at 8:47 PM, Coulomb said: for 1 kVA models, I don't think I've ever seen one. I've just realised that the 1 kVA 12 V models likely use the same firmware as some 24 V models, and I have a precious few of those. What is your present main firmware version number?
May 8, 20251 yr On 2021/09/08 at 7:00 PM, Coulomb said: I've just realised that the 1 kVA 12 V models likely use the same firmware as some 24 V models, and I have a precious few of those.What is your present main firmware version number?Helloi need like thes firmware V15.50 (1.2KW - 12V)
May 11, 20251 yr The only 15.xx firmware that I have is 15.61. This is firmware for an MC9S08AC48 processor (not using a TI DSP). It handles 1-3 kW inverters with 12 V and 24 V batteries.Available from a link in this post. Edited May 11, 20251 yr by Coulomb
May 11, 20251 yr 1 hour ago, Coulomb said:The only 15.xx firmware that I have is 15.61. This is firmware for an MC9S08AC48 processor (not using a TI DSP). It handles 1-3 kW inverters with 12 V and 24 V batteries.Available from a link in this post.MC9S08AC60 my IC and U1=15.50
May 12, 20251 yr On 2025/05/11 at 6:13 PM, Ibraheem Hayek said:MC9S08AC60 my ICAh! Yes, it would be. The last two digits are the flash size in kB. I was thinking of the 145 V max Solar Charge Controller firmware, which they squeeze into 48k.Considering that the TI DSP firmwares are 128 kB or 256 kB (parallelable models), they do well to fit it into 60k.
May 12, 20251 yr The Main (U1) Firmware02.65 Axpert MKS 1-3 kVA 12V all PF0.8 except two 1 kVA models. Freescale processor. April 2023.This working I need this
May 13, 20251 yr 16 hours ago, Ibraheem Hayek said:02.65 Axpert MKS 1-3 kVA 12V all PF0.8 except two 1 kVA models. Freescale processor. April 2023.This workingI need thisI think that you're far better off trying 15.61 first. 02.65 supports 7 different firmwares; 15.61 only 3. So 02.65 is likely to misidentify your hardware, possibly thinking it's a 24V or 48V model, which won't work at all.Ah! I see that the AEVA forum is offline again; a victim of another bot attack, I would assume. Sigh.I'll attach the 15.61 firmware link here; just ignore the SCC firmware.KS_1_3k_1561.zip But if you really want to try 02.65, very much at your own risk, it's here.This is main (U1) factory firmware version 02.65 for the Axpert KS (PWM) 1kVA/2kVA/3kVA using the MC9S08 processor. There are 7 possible ratings and battery voltages from 1 kVA to 3 kVA, all PF0.8, except for the 12V and 48V 1kVA models, which are PF1 (i.e. 1kW instead of 800W). Do not use with any other model or version. I l know little about these small models with the 8-bit processor, so use at your own risk. The hex file is dated 12/07/2021.Firmware upload instructions for these older models with a built-in rectangular display.This firmware supports only the PWM Solar Charge Controllers (usually about 100 V max PV voltage), not Maximum Power Point Tracking (MPPT) SCCs.hcs 02.65 Axpert KS (PWM) 1k 2k 3k 12V 24V 48V MC9S08 2023-4-11.zip
May 14, 20251 yr i test itthe 1561 the device work 24V not 12vand 02.65 working but after 2min stop working show U1 Ver flashing
May 14, 20251 yr 2 minutes ago, Ibraheem Hayek said:i test itthe 1561 the device work 24V not 12vand 02.65 working but after 2min stop working show U1 Ver flashingif you have 1550 i think will working
January 5Jan 5 Hola podrías decirme el firmwere de este inversor o donde puedo conseguirlo gracias. 3k pwm
January 7Jan 7 Please quote your existing main (U1) firmware version. There are so many variants with completely incompatible firmware. Edited January 7Jan 7 by Coulomb
