July 22, 20215 yr Hi Everyone, Maybe someone has some insight on this issue. I have 2x US3000c Batteries on a Growatt 5000TL inverter using BMS. But the SOC falls out of sync between the two batteries while draining/charging. Seen it go as high as 12% difference. However the voltages are near identical. When the one hits 95%+, it slows the charging on the higher SOC battery and it just hangs till they both rapidly "Jump" to 100%. I'm on firmware 2.1, and one is month old than the other (Due to getting a faulty one replaced). I was hoping they would fall into sync with each other over time, but it's been a few weeks now. Anyone have any ideas or have a similar issue?
