Deye + Lead Acid
I have a set of lead acid batteries on my deye 5k
Trying to figure out why I can see the battery on the inverter, and the batteries work when the power is cut... But I don't see the battery on the SOLARMAN app or online.
Is there something I have to enable for that to work?
Go to the menu at the top right, tap on 'Plant Info', then go to 'System Type', and change it to 'Storage System'. Tap 'Yes' at the bottom, and then 'Done' at the top right.
