October 8, 20214 yr Very Simple Python script to send loadshedding status to influxdb for use in grafana on raspberry pi Tip: If not already installed add the nano editor to your system, its just easier to use Now Create file called loadsheddingcheck.py You can do this i your home directory or anywhere you like to load your scripts, just be sure to change/edit the cron according to your preference. touch loadsheddingcheck.py Then sudo nano loadsheddingcheck.py Add (copy paste) the following code to the file and save (ctrl x y) from urllib.request import urlopen import json from influxdb import InfluxDBClient import datetime url = "https://loadshedding.eskom.co.za/LoadShedding/GetStatus" response = urlopen(url) data_json = json.loads(response.read()) print(data_json) theLoadsheddingChecker = [{"measurement":"Loadshedding", "tags": { "Country": "South Africa", "Utility": "Eskom" }, "fields": { "Stage":data_json } } ] influxdbClient = InfluxDBClient( host = 'HOST', port = PORT, username = 'INFLUXUSERNAME', password = 'INFLUXPASSWORD', database = 'INFLUXDATABASENAME' ) influxdbClient.write_points(theLoadsheddingChecker) Then add a cron to run every 30 minutes to check loadshedding status (or whichever check interval you prefer open cron editor (will ask which editor, use nano as its the easiest) crontab -e Then add the following line to the bottom at the last open line and edit to suit your requirements (the example below is for every hour). * */1 * * * /usr/bin/env python3 /home/pi/loadsheddingcheck.py > /home/pi/loadsheddingcheck.log 2>&1 ctrl x y to save Now in grafana add a Stat card and edit the settings and add some value mappings to show the correct stages. End result
