October 11, 20214 yr So I've noticed a few times now that load shedding has started that the PV feed stops and the inverter only draws from the battery. A restart of the inverter makes it come back. Any ideas if this is a defect, or maybe a bad version or firmware or a setting that I'm just missing? I've got my power export limit permanently on 0 and the SoC for on grid I change twice a day usually other than that everything is standard. Edited October 11, 20214 yr by D.J
October 11, 20214 yr Author Sorry I forgot to add that when I changed it to backup mode yesterday to charge the battery from grid to be ready for load shedding, then it only wanted to draw 325W even though I haven't changed the default charge or discharge amperage.
