November 15, 20214 yr you are correct @Morne SBR, the rest will go to charging your batteries up to 100% soc and then the pv will drop to just covering the load, the main reason for larger arrays is cloudy days. ps, looks like you have not used much electricity this monthย ๐๐ Edited November 15, 20214 yr by Tariq
November 15, 20214 yr Author 1 hour ago, Tariq said: you are correct @Morne SBR, the rest will go to charging your batteries up to 100% soc and then the pv will drop to just covering the load, the main reason for larger arrays is cloudy days. ps, looks like you have not used much electricity this monthย ๐๐ been running for 13 days , looks like the data did not pull through on the new loggerย
