RCT Axpert VM III with Pylontech US3000C
Hi all,
I have a RCT Axpert VM III 5KW inverter that I used with 4x Lead acid batteries.
I have recently bought a pylontech US3000C battery that I connected.
I have tried all the different cable configurations that I could find on powerforum but none of them work. I keep getting error 61.
I have now connected the battery under the USE setting.
I found this PDF that shows what I have to do. Has someone had to do this?
I dont know what to do anymore.
VM_III_Pylon_US2000_Communication_cable_check.pdf
Pylon US3000C 3.5kWh Li-Ion Solar Battery (excl. brackets): DIP switch has been deployed reversely. ON is down, OFF is UP. If DIP switches need to be 1000 then set it to 1110. MAX DISCHARGE AND CHARGE RATE IS ONLY APPLICABLE FOR +- 60 SECONDS. The maximum allowed voltage is 53.5V, please ensure that you check the inverter settings are below this BEFORE plugging in the UTILITY/SOLAR to the inverter. Please ensure that you have the correct BMS cable for the correct inverter.
