November 18, 20232 yr If you have a parallel system with 3x 8kwatt 1phase sunsynk inverters will you be able to ran one 1phase Generator to only one inverter gen input to regarge bTteries will that work or will the inverter coms pick up 2 missing fases ?
November 29, 20232 yr Love to chat with darrel lok...please help re single phase gen into 3p sunsync Edited November 29, 20232 yr by tdovale Typo
July 15, 20242 yr On 2023/03/31 at 9:09 AM, darrellok said: I have a 12 kva 3 phase Sunsync inverter and I use a single phase genie to charge the batteries when I need. It switches on and off accorcing to the paramaters that you set on the app works like a bomb. Hello, this might be too old. Can you kindly share how you did this? If possible.
May 12May 12 On 2023/03/31 at 9:09 AM, darrellok said:I have a 12 kva 3 phase Sunsync inverter and I use a single phase genie to charge the batteries when I need. It switches on and off accorcing to the paramaters that you set on the app works like a bomb.How did you connect it?
