I want to know protocol used in ISolar SMG II 5Kw
i'm trying to read the values from the modbus with node-red, but i can't, if i set port 502 it doesn't connect to the modbus gateway, if i set port 80 it's fine, it connects but of course it doesn't read the values.
Some idea?
  • Replies 98
  • Views 53.3k
  • Hello all,   In case is not too late and you didn't abandon the project I can confirm that the above protocol is the one used. After many nights spent to reverse-engineering I was able
  • Wow. That's very different to Axperts. Strange that they don't specify the bit rate, parity, etc.
  • Hello, Also I'm looking for easun SMX II 5.6 kW protocol. Edit: I found that SMX II 5.6 is compatible with SRNE inverters protocol. I tried https://github.com/shakthisachintha/SRNE-Hybr
I answer myself.
esp-home can only read data from a modbus device and send it to homeassistant.
It is NOT a modbus gateway.
If you want to make the esp32 a modbus gateway, another firmware must be installed.
One solution is to create a flow with nodered, take the data from homeassistant and maybe send it to emoncms for example...
Hello,
from ESPHome you can send data to HomeAssistant, but also to a MQTT server.
Then  Node-Red could read data from MQTT server (for example Mosquitto).
mqtt:
  broker: 192.168.2.32
  client_id: esphome_m5stack_220
In this way all your sensors will be sent also to MQTT.
Using "MQTT Explorer" you can check which messages where sent.
You can also define a custom message
sensor:
  - platform: sdm_meter
    address: 10
      active_power:
        unit_of_measurement: "W"
        device_class: power
        on_value:
          then:
            - mqtt.publish:
                topic: domoticz/in
                payload: !lambda |-
                   std::string messageO;
                   char str[16];
                   snprintf(str, sizeof(str), "%.2f", x);
                   messageO += "{\"idx\":438,\"nvalue\":0,\"svalue\":\"";
                   messageO += str;
                   messageO += "\"}";
                   return messageO;
Note that if you configure MQTT integration in HomeAssistant, then you will have double messages on HomeAssistant from ESPHome, just use one
Hello, I also created a yaml file for my SMX-ll 3.6 inverter and loaded the firmware into the data logger, which can be integrated into homeassistans. to do.
Here is the yaml if anyone wants to hack in Hungarian
esphome:
  friendly_name: Easun SMX-ll Inverter
esp8266:
  board: esp07
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: ......................................................
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Easun-Smx-Ll-Inverter"
    password: ".............................."
web_server:
  port: 80
captive_portal:
uart:
  rx_pin: GPIO3
  tx_pin: GPIO1
  baud_rate: 9600
  stop_bits: 1
modbus:
  send_wait_time: 200ms
modbus_controller:
  - id: easun
    ## the Modbus device addr
    address: 0x1
    modbus_id: mod_bus_1
    command_throttle: 200ms
    setup_priority: -10
    update_interval: 20s
sensor:
  - platform: modbus_controller
    modbus_controller_id: easun
    register_type: holding
    address: 0x0100
    unit_of_measurement: "%"
    value_type: U_WORD
    address: 0x0101
    unit_of_measurement: "V"
    value_type: U_WORD
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 0x0102
    unit_of_measurement: "A"
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Akkumlátor Töltés Napi"
    address: 0xF02D
    unit_of_measurement: "Ah"
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Akkumlátor Fogyaszás Napi"
    address: 0xF02E
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Napelem Feszültség"
    address: 0x0107
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0108
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0109
    value_type: U_WORD
    name: "Napelem Töltés Napi "
    address: 0xF02F
    unit_of_measurement: "kWh"
    value_type: U_WORD
    filters:
      - multiply: 0.1
    device_class: energy
    name: "Inverter Feszültség"
    address: 0x0216
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0217
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0218
    unit_of_measurement: "Hz"
    value_type: U_WORD
    accuracy_decimals: 2
    filters:
      - multiply: 0.01
    name: "Inverter Dc Hőfok"
    address: 0x0221
    unit_of_measurement: "C"
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Inverter Ac Hőfok"
    address: 0x0222
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Inverter Tr Hőfok"
    address: 0x0223
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0xF030
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Napelem Halmozott Termelés"
    address: 0xF038
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "Inverter Halmozott Fogyasztás"
    address: 0xF03A
    value_type: U_WORD
    filters:
      - multiply: 0.1
select:
    name: "Kimeneti Prioritás"
    address: 0xE204
    value_type: U_WORD
    optionsmap:
      "SOL": 0
      "UTI": 1
      "SBU": 2
    name: "Energia Takarékos Mód"
    address: 0xE20C
    value_type: U_WORD
    optionsmap:
      "KI": 0
      "BE": 1
output:
  - platform: gpio
    pin: GPIO0
status_led:
  pin:
    number: GPIO4
    inverted: false
binary_sensor:
- platform: gpio
  pin:
    number: GPIO12
    mode:
      input: true
      pullup: false
    inverted: true
- platform: gpio
  pin:
    number: GPIO14
    mode:
      input: true
      pullup: false
    inverted: true
13 hours ago, pongo said:
Hello,
mqtt:
sensor:
    address: 10
      active_power:
        device_class: power
        on_value:
          then:
            - mqtt.publish:
                topic: domoticz/in
                payload: !lambda |-
                   char str[16];
                   messageO += str;
                   messageO += "\"}";
                   return messageO;
Hi Pongo,
I've activate MQTT on Esp-Home dongle and now inverter send all data to mosquito, but there only numbers...
Please can you explain me a little well how to setup it?
Hello,
what is supposed to view on Node-Red?
You can pass sensor values from Inverter to Node-Red via MQTT, then on Node-Red can select specific topic (sensor) and do what you want with it.
For each inverter sensor/button/... you will have a specific topic on MQTT, for example:
On EpsHome:
On Node-Red:
EspHome:
Node-Red:
If you want to use Node-Red, I suppose you know how to use it. Otherwise, why to use it?
Edited by pongo
19 minutes ago, gazzzzton said:
you must set your own wifi password at this place
I don't have Home Assistant and I have no way to upload my yaml configuration at the beginning. I want to run ESP Logger and send to MQTT to Domoticz
I think you must find and try other firmware to put in esp because esphome works only with homeassist.
On GitHub I think you can easy find a firmware that read data from modbus and send it to a mqtt server
I found a solution, maybe it will be useful to someone.
https://www.google.com/search?q=esphome+compile+on+windows&rlz=1C1GCEU_plPL1007PL1007&oq=esp-home+haw+compi&aqs=chrome.1.69i57j0i22i30l9.18892j0j15&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:b93dd58f,vid:a3iay-g1AsI
You don't need HomeAssistant, you need to install EspHome. And you need original yaml file where you can change everything (including wifi password).
Inside yaml file you can enable/disable HomeAssistant integration and also can send data to domoticz:
If you put
api:
you enable HA integration, if you don't then no integration.
To send data to domoticz:
sensor:
    modbus_controller_id: dds666
    address: 0x2004
    device_class: power
    value_type: FP32
    filters:
      - multiply: 1000
    on_value:
      then:
       - mqtt.publish:
           topic: domoticz/in
           payload: !lambda |-
              char str[256];
              snprintf(str, sizeof(str), "{\"idx\":25666,\"nvalue\":0,\"svalue\":\"%.2f\"}", x);
              messageO += str;
              return messageO;
Edited by pongo
If you put
api:
sensor:
    address: 0x2004
    device_class: power
    value_type: FP32
    filters:
      - multiply: 1000
    on_value:
      then:
       - mqtt.publish:
           topic: domoticz/in
           payload: !lambda |-
              char str[256];
              messageO += str;
              return messageO;
Thank you for your help. I am also uploading another project for ISolar/EASUN SMG II
https://github.com/syssi/esphome-smg-ii
