Finally got my setup finished, Sunsync 5KW with Hubble AM2 and the 540w panels.
Yesterday the installer finished everything, was some trial and error getting it to push back to the geyser, but it was working, PV draw spiked when I turned the geyser on, Grid levels remains at trickle settings so all looked good.
Today, no joy, geyser went on at noon and the PV relaxed at under 300w.
This morning I updated the work mode settings as the battery switched off and went back to the grid last night with the default settings, not sure if that could have messed with things.
Tinkered with mode 2s settings and only managed to briefly push over 4kw to the grid, or maybe just the CT clamp, not my area of expertise, but the grid gauge on Solar Assistant was in the negative.
Not sure why it worked yesterday and not today and other than the work mode settings, everything else I tinkered with I restored to their previous, other than that the only difference between today and yesterday is the dongle was plugged in, but I cannot image that could be the cause?
is this a settings thing I can do myself or do I ask the installer to re-re-re-check the wiring?
Question
RemeJuan
current settings
TIA
Link to comment
Share on other sites
4 answers to this question
